J
James King
Guest
" Jon i have a 75 horse chrysl
" Jon i have a 75 horse chrysler and got it running after carb rebuild but while on the muffs, upper bearing in lower unit failed.i dis-assembled and it had been bad a while.got the new parts,bearing,seal and water pump.installed no problem. i was reading a post about filling the lower unit with oil. chrysler mechanic: from a chart on his wall said 27ozs. o.k. but i had always heard to fill from the bottom until it comes out top hole,well i takes close to 45ozs of oil to do this. this is how i did it. took the boat out on the third day noticed i could smell 90wt. everytime we stopped.well a short time later it let me know it had no oil. got home and pulled drain and nothing but water. take it back apart and the seal under the water pump above the upper bearing had pushed out. bearings and seal were fine so reinstalled seal a little farther in the recess and staked in 4 places hoping to eliminate this again. so my question, did i overfill causing pressure to push the seal out and what if 27ozs is not enough? i know i will find out the hard way on that one,but that bearing cost me $54.00 and i really don't want to do it again. also they call that top hole the "vent" but it does not vent anywhere.so pressure is bound to build up? thanks Jim King "
