QUESTION FOR JOE R
G
Gary G
Guest
" Joe....What is the differanc
" Joe....What is the differance between a QL77JC4 and a UL77V other than the electrode...I took your advice on my 1974 70hp Evinrude and used QL77JC4'S and it seemed to run better with the UL77V plugs, at lower speeds.
Gary "
"Gary..... The "Q" ind
"Gary..... The "Q" indicates a suppressor plug which is designed to help quiet noise/static/interference in any electronic equipment you might have installed. The "77" indicate the heat range. The "C" indicates a copper electrode for long life.
Strange.... the QL77JC4 plugs should have the engine running better at all speeds. I'm assuming that you did set the plug gap to .040 .
Joe
" Yes I did...I know what all
" Yes I did...I know what all the numbers and letters mean. I'm not really interested in a suppressor plug, my boat has no electronics. I know the UL77V cost more but are the UL77V plugs supposed to be better performing. What is the advantage, if any, in using them ???
Gary "
The UL77V plugs really have n
The UL77V plugs really have no heat range to speak of regardless of the 77 rating. They last just about forever but are prone to fouling at low rpms.
