"Gary.... 1/4" ID will wor
"Gary.... 1/4" ID will work just fine.
Mike..... The proper way to fill the lower unit is to fill from the botom drain plug hole until the lubricant flows out the top oil level hole. If you attempt to fill at the top oil level hole, you'll encounter a air pocket and will not be able to fill the unit as it should be.
NOTE: (MarineEngine.com - Properly Inserted Post)
Go back to the previous page where the various topics/questions are posted. Scroll down to the extreme bottom of that page.
There you will see a large button that is entitled "Start A New Conversation" or something of that nature. Click on that button and you will be able to have your post listed under your own topic which will be inserted at the top of the page.
As it stands, your post is buried under someone elses topic which started at a prior date and/or time.
HINT: Click anywhere on that page whereas the click won't initiate anything, then hit your END key. That'll drop you to the bottom of the page immediately.
Joe
