enginesilo
"What is the procedure to test
"What is the procedure to test a lower unit? After checking the current oil to see if it has any water mixed in, is whitish or creamy, the next step would be to pressure test the Lower End.
Can a typical gauge pump or carburetor pop off tester sufficiently test the pressure of a lower unit?
What is the procedure and what is the pump or tool needed. Could the pump be built?
How long does the unit need to hold pressure for, and at what psi?"
