A
AlabamaRan
Guest
" I was running UP a canal the
" I was running UP a canal the other day and they were pulling water, HARD. Anyway, as I was going AGAINST the current, my little 70 model 9.5 felt and sounded like it jumped out of gear. I immediately backed off the throttle and checked. Nope. The shift lever was engaged as if the motor was still in gear. I pushed it back to neutral, then back into forward. It geared up and I was off again. Then it did the same thing again, and I did the same thing again. This time though, after I re-engaged the gears, I just eased the boat forward at a slower speed and it did fine. Now my questions and concerns.
What happened? (smile) Could the "force" of the current against the WOT push the gears and force the motor to jump back to neutral?
Did I do any damage to the lower unit or gears (Once out of the canal, the motor pushed fine without any noise such as grinding, clunking, or anything out of the ordinary)?
Is there some kind of built-in mechanism to prevent the force caused by the current against the propeller from causing gear damage (for example, pushing the engine to neutral rather than busting a gear)?
I have just never heard of this condition nor have ever had such a thing happen to me before. Any thoughts, tips, sugestions, etc. are very welcome and appreciated. "
