Jason Davis
Hello,
If the shift shaft height is off a turn or 2 is it ok to adjust it out with the shifting cable adjuster? I ask because I just put the powerhead back on my boat and it would go into reverse and neutral fine, but not forward. So I assume the shift shaft must have turned a time or two while I had the powerhead off. I adjusted the shift cable a bit and now it goes into forward/reverse/neutral fine. Is this OK?
Also, while running with the ear muffs on, I notice that the water that comes out of the motor has a very slight oil sheen to it. Is this common? Could It mean Im running rich? The motor seems to run fine at all speeds otherwise.
1988 88hp Evinrude Outboard
Thanks!
Jason
Thanks!
Jason
