QuadraJet Carb
I need a rebuild kit for QuadraJet carb. The casting # 17059292-1658 I found on the side of the carb and the jets are 69's. The kit I need will need to have the accelerator pump and the jets. Just the gaskets will not due me much good if I cant get the jets and the accelerator pump. This is on my Formula, F18 boat with the 5.0 chev motor. Naturally my boat is to old for Formula to have information on it. Got any ideas where I can find these part, and the automotive parts stores do not have them. Thanks for your help.
there is no rebuild kit on the market that comes with jets for a q jet. go to a carb specialty shop....they can spec out the jets you need.
I was actually able to find a QuadraJet MFG on line supply . QuadraJet was able to match the numbers to a Q4016 and they fixed up a kit with the 69 jets and a float. There kit comes with the accelerator pump. The auto part do not.
The address is QuadrajetParts.com, and they had all the parts for my carb, and I was able to use the numbers on the body to cross reference my carb to be a Q4016. Hope this helps.
no it would idle but I bought the boat used and it has a lot of hesitation. I can give the engine full throttle and the engine will rev up a little and go about 300 yards before it will actually speed up and plane and get up to 55.
The kit I recieved from quadrajet.com is an excelent kit. I have installed the kit and I now will need to wait till it warms up so I can set the fuel jets. The carb when I took it apart had oxidation on the bottom of the float chamber and the old jets were croaded up.
Very common for a marine carb.....typically there is always a small biuld up of water and that never seems to leave the bowl area and causes the oxidation. also due to boats sitting for long periods of time most if not all the gas in the bowl evaporates thus the water/moisture oxidizes....
partner2.jpgTrying to upload the pictures of the quadrajet parts I recieved and some how I eraced the picture and downloaded my dog a work. Cant remove the pic of my dog and cant find the pics of the parts. I wil try again. Sorry
