seahorse10
I have a 1955 Johnson Seahorse 10hp (QD16) and this is my first boat and first motor and I am having trouble with an intermittent miss. Last spring I rebuilt carbs and the entire ignition system:
2 new coils, new points, new condensers, new wires, new connections to spark plugs and new Champion spark plugs (as recommended). Everything is gapped as well as I can make it with my knowledge – points at .020, coils matched to the plate with a straight edge, etc.
I had it running pretty well last year (though I was only able to use the boat a few weekends) but near the end of the summer I was getting an erratic miss every once in a while under ¾ to WOT throttle while in gear.
When I started it up this year I initially thought that I was good to go as it started on the second pull…then I realized it wasn’t cooling properly. Since we had an extremely cold winter I erred on the side of caution and replaced the impeller, impeller plate, & o-ring on the shaft. I put it back together and we were back in business...so I thought.
I started getting a miss the miss on occasion, so I started adjusting slow and high needles to see if I could get it to settle down. It seemed to smooth out and ran well in idle and when in gear so I figured I just needed to tweak my fuel mixtures and keep an eye on things. Then I came back the next day and the miss was much worse and was happening in idle but was very bad when in gear. At this point I took off the flywheel to inspect the ignition set up. I immediately noticed that both coil ground wires were rubbing on the center of the flywheel and had caused a short as the wire was rubbed down to copper. At this point I was rather frustrated, I pulled out a meter and tested continuity for the coils – primary and secondary seem to be okay so I used RTV silicone to cover the exposed wire and to hold the ground wires in place closer to the coil so that it would not get caught by the fly wheel again. I reinstalled and reset all gaps.
Seems to now run fine, at times for a minute or so, and not at other times. I will start the motor and get only a few light misses and I will shut it down and restart and then it sounds like one cylinder is dead and it is missing heavily and constantly. I have two new coils on order but I wanted to reach out to all of you to see if you have any other ideas – if you don’t think it is the coils then please let me know and I will not install them and save (or invest) the money somewhere else if need be.
I appreciate any and all help.
Thanks,
Chris
Thanks,
Chris
