Matthew Sharpless
I have a 1976 35 hp johnson seahorse model 35el76g. Its eletric start and I put a tiller handle on it. I finally figured out that I had no spark thanks to the blue/white wire from the wiring harness. It was connected to #1 plug wire with a quick connect. So me being an idiot cut them and wired a kill switch in incorrectly and shorted out my soleniod. So I have since reconnected the #1 plug wire and have the kill switch wire unattached. To make a long story short I don't know how to wire the kill switch in everyone tells me to wire it to the blue/white wire problem is the wires from the #1 plug coming from the ignition assemble is dark blue/white and the kill switch wire from the harness is light blue/white. I can't figure this out. Do I run one end of the shorting switch wire to the kill wire from harness and then the other into the #1 plug wire? Any help would be greatly appreciated.
thanks
thanks
