Push rods
mrpops
"had a nice episode happen the
"had a nice episode happen the other day ,turned 454's over for preseason prep and heard a noise that sounded like pipes rolling around . on investigation, removing valve covers ,found three bent pushrods.now time for repair"
"Common problem with that engi
"Common problem with that engine, which like to suck in water through the exhaust ports. That leads to rusty valve stems that stick, followed by a bent push rods. A valve job will cure it.
Jeff
PS: Some folks have added spacers to the manifold/ riser joint (IF so equipped) to get the riser higher (still) than the waterline."
