"Hi all, 92 johnson 70hp. Bee
"Hi all, 92 johnson 70hp. Been having some VRO problems lately. Wanted to check the pulse limiter. The manual says one way valve but I can easily blow through both sides. It maybe is slightly more restricted on the engine side but I can still blow through either way. Is this an issue? Could this be my problem and not the VRO pump itself? I run pre mix, oil side is plugged.
Does anyone know if it should blow both ways?"
