mtuck02
Looking for some advice / direction. In the process of rebuilding Chris Craft 283 for use in Jersey Sea Skiff. Tearing down the block and am at the point where normally the harmonic balancer would be on a car engine. Instead, it has a gear that will go into a manual paragon trans. (This is I guess what you would call an opposite rotation engine and has a large gear on the cam meshing with the crankshaft gear instead of a timing belt).
How difficult is it to pull the gear? What should I use and anything to look out for.
I am following a "How to Rebuild a Small Block Chevy" book and I need to obviously deviate for any marine specific part.
Pics attached, thanks!
Tucker
Tucker
