393Clevor
Long story.... lol
Ok from the start, bought this 1956 QD-17 10hp and from the get go it ran like poop, backfiring, misfiring, stalling.. got bad enough it sheared the key way on the flywheel..
I replaced coils, points, condensers, new solid core wires and spark plugs, rebuilt the carb, set the timing, you name it I have done it.. still runs like poop...
go it out on the water and it ran good wide open was able to adjust the high speed needle, idled great adjusted the low speed needle.. anything in between idle and wot it backfires spits and sputters..
So I setup a tank at home and fire it up, I hooked my timing light to it and this is what I found..
Lower cylinder I get a constant fire, the light is steady and on the money no matter where I move the magneto..
Upper cylinder fires all over the place not consistent at all (I thought I had a video but I don't) at idle the light on the upper cylinder is constant like it should be but as soon as you move the mag it starts jumping all over the place and cuts out completely (no light at all) only running on one cylinder..
I had it running on the throttle stop in neutral and it was only running on one cylinder with the other coming in and out, I lifted up on the mag plate and the dead hole came to life.. I let go of the mag plate and it cuts out clear as a bell, lift up on it the dead hole fires, let it go it dies..
I checked the mag and it's seems to be tight on it's mount (well just as tight as the other 10hp I have)
I measured both mag plates I have and both are with in a few thousands, I measure the top of the blocks where the mag rotates and both motors are with a few thousands..
So what I did notice was the mag mount on the 61 10hp (the brass part) was just a little thicker and when I used that mount it seemed to tighten up the play in the mag plate.. I put it back together and it seems way better (watch video and listen closely as I rev it up you can hear it still missing from time to time) at the very end you will see/hear what happens when I lift up on the mag plate.. I thought I had it fixed at the beginning of the video but it stated to skip again at the end..
I have checked the point gap every 10* of the magneto rotation lifting and moving the mag plate and the gap stays constant.. Today I am going to change out everything on the upper hole one piece at a time till it's right..
I was thinking maybe a bad ground but that would effect both cylinders..
just so you know before I changed the mag mount it would cough spit and sputter and most of the time die when you moved the throttle off idle in gear.. In this video it is 100% better so I'm gaining..
at 25 seconds into the video you can hear the top cylinder cut out and when it comes in it's clear we have both cylinders firing..
https://www.youtube.com/watch?v=wryTArPhljM
