Hey all. Im Pulling my hair out with this darn port engine on my 88 Sea Ray 300 with twin 260s. Ive rebuilt the port side carb 3 times now and finally gave up and took it to a pro. I got Both carbs back and still am having the same issue out of my port side engine. I can fire it up and warm it up and it runs great 90% of the time. When it finally gets up to temp and I pull the throttle back from 1100ish rpm it will load up with fuel and stall. I can hold it wide open and it will restart and clean up and be fine. So ill be on my way to our hangout spot (the engine performs as it should above 1000 RPM in gear) and when I pull the throttle back it will load up with fuel and stall. So the other day while beached i pulled the hatch and tapped the carb with a screwdriver handle a few times. I cranked the engine and it fired up and idled great for 10 minutes. So i took it for a cruise for about 10 minutes and came back to the beach, pulled the throttle back and it stalled again. Does this sound like a carb issue or possibly a pump issue? Ive checked the sight tube and there doesnt appear to be any fuel in it from a busted diaphragm.
