FstaRockr Burns
Hi all - so pulled my powerhead today on my 90 mariner 60hp.. the whole drive shaft was covered in black soot.. and the inside of the "leg"as well, esp near the top - it was crudded on there.. I also had oily nasty stuff getting coughed up thru the right top mount (rubber was missing) spraying black spots everywhere..
The manual was a bit vague about what bolts to undo - either way.. see the pic.. did i undo the correct bolts or must i remove the plate still attached?
I basically destroyed the adapted plate gasket - i can see the crank nose inside there, but do I also have to remove the exhaust plate to change the seal?
this is the view of the exhaust tube - the crank is inside the hole on the right.. is that where the seal is? and did I take the wrong section apart?
Also - anyone know what thread the powerhead bolts are? I literally had to chisel all mine off - except for two.. luckily no damage to the studded threads - im def going s/s on these!
