Props trurning while in nutral trs drives
J
Julie Mazzotti
Guest
" Props turning foward while i
" Props turning foward while idoling in nutral. I have trs drives. Do I need a new transmission and where can i locate one. its a 35 ft,1987 webcraft, with twin 454's and 360hp. "
I have had the same problem w
I have had the same problem with a BW Velvet Drive tran for at least 3 seasons. The transmission creeps in neutral. No amount of adjustment corrects the problem. I have been told that this is not unusual esp for an older trans but indicates wear and I plan to either overhaul or replace this spring. I have not had any problems other than creeping which is a bit of a nuisance when docking.
