Proper Timing
"Ayuh,...
This is the Mercr
"Ayuh,...
This is the Mercruiser forum,....
Mercruiser doesn't use righthanded motors....
Maybe alittle clarification to your question is in order,...??..."
"I know this is a dumb questio
"I know this is a dumb question but dumb is what I do best. My motor rotation is ccw, I assume this means counter clockwise. Is this considered a "left handed motor" ? Also I was wondering do car engines run ccw or cw? I am sure I could find this info in the manual but the last question and answer in this thread just made me wonder. thanks"
Mike;
Most domestic car engin
Mike;
Most domestic car engines and boat engines turn CW when viewed from the front.
This translates to LH in boat speak; which is as viewed from the stern.
Most drives are standard RH; which means the prop turns CW from behind.
A counter rotating drive is LH; the prop turns CCW from behind; meanwhile the engine is still a LH rotation. The change is done in the lower gear case of the drive.
Rod
