"My 1989-90 454 Crusaders have
"My 1989-90 454 Crusaders have a fuel water separator filter mounted on the engines between the tank and the mechanical fuel pump. The Rochester Qjets also have a filter inside the inlet fitting. I seem to remember reading posts (Jeff or Rick?) indicating that the fuel/water separator filter should not be located between the pump and the tank, but between the pump and the carb. I can't locate these threads and not sure if that recommendation was for electric pumps only. Do I remember correctly, and, if so, what is the reason for this recommendation? I believe my setup is original from Silverton and has not caused any problems yet.
Thanks,
Erich"
Thanks,
Erich"
