Fairliner62
After 20 years I am repowering my boat. Engines are new GM 350's (5.7L) which are direct replacements for the old engines. Engines have closed system fresh water cooling but exhaust is raw water cooled (saltwater).
Exhaust manifolds have been Marine Power log style, and yes they lasted all this time! However they are out of production and I have been unable to find replacements.
I have obtained Mercrusier type center riser manifolds for replacements (Osco - 3" exhaust). I want to get the raw water flow thru the manifolds correct.
Would the correct flow be water in the bottom of the manifold, which would continue thru the water jackets thru the riser then out the exhaust?
Or should the flow split, one hose into the bottom of the manifold, one into the rear of the riser?
Also is a "balance hose" necessary between the two risers on each engine?
Thanks in advance for any information
