My 1986 Bayliner is equipped with an AQ131 engine and 275D drive.
The "D" typically indicates the final drive reduction. In your case, the AQ 131 engine requires the 2.15:1 reduction, indicated by the "D" in the serial number.
I am in the process of removing the transmission in order to service the U-joint assembly, the steering yoke bushings and possibly the primary drive shaft bearing and seals, if needed.
My question: I have found separate parts listings for the 275 and 275A drives, but no specific listings for the later 275 series (B - D..).
The alpha characters B, C and D indicate the final reduction. With exception to the E transmission, the reduction change occurs within the lower gear unit!
B= V-8 or 1.61:1 over-all reduction
C= 6 cylinder or 1.89:1 over-all reduction
D= 4 cylinder or 2.15:1 over-all reduction
Can I assume that the parts for 275A are interchangeable with the 275D series?
The 275A transmission uses the integral aluminum clamping ring/bearing box. In other words, the clamping ring and bearing box are one unit.
The 275 transmission uses a separate aluminum clamping ring with a separate steel bearing box.
Those parts will NOT interchange between transmissions.
I intend to order at least: 1) O ring between the upper gear case and intermediate case;
Yes..... there will be two (2).
One oil drain back tube O-ring, and one large bearing retainer O-ring.
These will be the same p/n between the 275 and 275A drive models.
2) steering yoke bushings and seal.
The two plastic collar steering fork bushings and the V-ring seal will be the same for the 275 and 275A. (not the same for the 270)
I may also need new shims between the gear case and intermediate case.
If you are re-installing the same transmission, and if the shims were correct to begin with, there will be no need to change the shims.
However, if you are installing a different transmission, you will need to go through the shimming procedure.
In either event, the new bearing crosses can be a Spicer 5-1306X.
The AQ series drive shaft bellows will all interchange. VP p/n 875826-0, 876294-0 or Sierra p/n 18-2744
Your PDS bearing will be an industry standard 6206...... about $14 from a good bearing supplier. Since there is no good way to test it's condition, I would replace it!
The AFT seal will be a 35X62X7mm in a TCM or Timken single lip..... about $7 from a good bearing supplier. (make sure that the AFT seal is installed in the "non-conventional" direction) The FWD seal may be smaller, and it may be difficult to remove with the engine installed.
The two small O-rings for the dip stick and drain plug are the same p/n.
I would suggest installing the the drain plug with a hand held impact driver and a large straight blade tip. Give it just a few mild blows with your hammer.
