knuckle47
Advanced Contributor
"When I dis-assembled the moto
"When I dis-assembled the motor, the intake manifold bolts had a slight flare to the head as it it had a built in flat washer. You know the type? Any how, upon re-assembly, I can find grade 5 or 8 bolts but unless I go to CHevy, I will not likely find these bolts as new...is it recommended to use flat or split ring washers on the intake manifold as well as the exhaust manifolds? Thanks AGAIN!"
