I recently removed the propeller shaft and I am having to replace the bearing carraige. I am having trouble aligning the cam plunger so that the engine will be in the reverse position. I seated the foot into place and the prop was not spinning when the control was in nuetral position. How can I position the Cam so the plunger in the end of the propeller shaft is riding in the proper position on the cam. I notice that the prop does spin free when the cam is at it's highest point, however, when I seated the foot with the lower unit in nuetral the controls did not work properly.
