Harold Lee Miller
Sheared the prop drive pin on my Johnson 4r71d 4hp direct drive motor couple days ago. Ordered a new pin. While I'm waiting for it to get here, I noticed the slot the pin fits in behind the prop is a bit wedge shaped, and the piece of broken pin I took out of the driveshaft doesn't fit into those slots from "above" -- it's like they need to be slid in from the side?. Never replaced one of these so not sure if I need to disassemble the prop to get it in. I assumed I could insert the pin into the driveshaft and then the pin would fit into the slots as I put the prop back on the driveshaft. Thanks for any guidance --
