"Hi guys,
I have a Regal Amba
"Hi guys,
I have a Regal Ambassador 233XL 1988 with a Merc 5.7 Alpha 1 1.47 ratio. The boat weight is 5000 lb dry. I run it with a 17" alum. prop.. My WOT is something lika 4400 RPM and run realy fine whit 2 or 3 peoples on board. Get out of the hole at 3100-3200 and can hold it at 2900 RPM. My problem is like this week, with 7 peoples on board (5 adults (170 lb each) and 2 young (100 lb each) plus 2 full cooler..). If the boat is well balance (body on the deck and on the aft), not to much problem, exept a little bit more RPM to stay out of the hole. But if all the people are in the back, I can't reach more than 3200-3300 RPM and can't get out of the hole, or may be after very long time.
My oppinion is I need to under prop. when I have a lot of people on board, Something like a 3 blades 15" or 4 blades 16" or maybe a piranha prop with a couple set of different pitch blades.
You guys, what do you think about that???
I'm not in the reach of speed, but a nice ride with the best GPH possible (I know good GPH and boating don't go with each other)
The prop calculator, if I remember, give me 17".
Thank you,
Phil"
I have a Regal Amba
"Hi guys,
Thank you,
Phil"
