Prop seal
puncho378
Would anyone know what seal would be causing this leak? Photo
Its leaking out from around the outside of the prop.
Its a 2005 4 horsepower 4-stroke
Serial number: 0R057323
You'll need to remove the prop- the propshaft has seals and the bearing carrier has a seal at the front, usually a large O-ring if it's the same as the way Mercury/Mercruiser does it.
Propshaft oil seals often have fishing line wrapped around the shaft and when it enters the seal, it wears the rubber, causing leaks.
