Prop pitch
jjdluz
"is higher pitch prop make boa
"is higher pitch prop make boat go faster or slower?i have 4 hp yamaha outboard as kicker,like to make my boat go faster,didnt know i need higher pitch prop or lower pitch prop make boat go faster?thanks for any advices."
faster the higher pitch
but y
but you need to be at the right rpms before you start to play with things
"Jason, as Just-In-Time notes,
"Jason, as Just-In-Time notes, higher pitch will give you more speed unless the pitch is too high, in which case it will simply bog the motor and give you less speed than less pitch - confused now
You are talking about a 4 horse kicker. Your pitch selection will be very limited for that motor and may not vary by 1 or 2 inches max. In any event, there is almost nothing you can do to that motor, using it as a kicker, to give you a significantly noticable speed increase.
Depending on what size/weight of boat you have it on and what you are using it for (trolling etc) total replacement may be your only option if it does not suit your needs..."
