Prop number of splines
sashko1
I need a new prop for 1970 Joh
I need a new prop for 1970 Johnson 60HP.
1) How do I know the number of splines on the new prop that I'm planning to buy? Do they come standard number?
2) What about the diameter of the shaft that the prop is supposed to fit? Is that standard per engine?
"You have a choice of quite a
"You have a choice of quite a few options, depending on the size and configuration of your boat, and what you want ... that is, top speed vs. "hole shot"!
Take a look at the listed props (#100 on the diagram) here:
http://www.ishopmarine.com/ishop/jsp/AsplIsmCcatViewBase.jsp?&lvlCode=5&pCode=C0 209384&path=BRP~A0000008~M0012101~M0012107~M0012108~C0209384&isFromCMS=false&hid eAdd2CartButton=&isStandAlone=&is4CmsShop=&reqln=Unknown&reqem=Unknown&reqph=Unk nown&reqFor=29&req4Browse=1&docId=&docName=&isForSupStore=true&cCatFilter=BRP&eC atSupFldr=supplier-100-005-EJ
I'd recommend that you find a local seller who's knowledgeable about selecting the best propeller for your needs!"
