EvinrudeIntruder175
Solved my fuel/oil issue finally! Now for some fine tuning! I have a 1991 Ranger 481V powered by a 1991 Evinrude Intruder Spitfire 175hp. Prop is a stainless 4-blade cupped tip OMC Shooter 27pp. According to the specs on my motor the optimal rpm range should be between 4800 and 5500. I am barely making 4700 rpm at WOP and just over 55mph on GPS. This boat with this motor setup should be pushing over 60mph. It has a Pow'r Drive jack plate by Springfield. When running WOP, my water pressure is approx 23psi. I have never adjusted one before and have no knowledge of specific prop usages. My holeshot is good, top end is my issue. Should I start with trying new props? Or raise Jack Plate some first?
