my boat is a 20' baja closed bow 350 v-8 alpha 1 gen 2 mercruiser. my problem it has a 21 pitch stanless prop on it i also trim tabs that helped but still not right, when you stand on the throttle it runs up 2000 rpm then real slow two plane out. real boggy. i found a 18 pitch prop from iboat that is recommend for the alpha 1 gen 2 what do yall thank wanted to ask you guys before i buy it?? thanks alot yall are real helpful!!
