I have a 1987 Mariner 15HP (titled as such at least, I'm not the original owner) and I'm looking for a replacement prop.
Here's the model / serial number: 15M 684C S 037408
The 3 blade prop currently on it (damaged by thieves as they tried to steal the whole outboard) is a 9.25 x 12, and also has 3920R stamped on it. It has 8 teeth / splines.
I've not had any luck finding a replacement online that is the same diameter and pitch. I'm not sure how advisable it would be to go up to a 10" diameter, but it would just clear based on my measurement, although a 10.5" diameter would definitely not work. I only mention the 10" diameter as a possibility because I've seen one listed online that claims to fit a 1987 Mariner 15HP that is 10 x 13 and another that is a 10.5" diameter that is 10.5 x 11.
This outboard is run on an old 14' Sears aluminum featherlight. I'm honestly not sure if the current diameter and pitch is the right fit, but I can tell you that it makes that boat fly. It is almost too fast, IMO, when there's only one person in the boat.
Any help / prop suggestions would be appreciated...
