Count your prop shaft splines and measure the diameter of your gear case, then use the Solas Prop Finder Tool here on this site. As Droid said, you're most likely going to use a 17P or 19P prop. Make sure your tach is working correctly and test your props until you can achieve 5500 at WOT with a normal load. As a general rule, each 1" change in pitch will cause a 150RPM change, so adjust your prop pitches accordingly.It's a 17' bowrider.
