"Hey everyone,
I have been w
"Hey everyone,
I have been working on my project boat for several weekends. I only get a few hours a day so I havn't made the progress that I would like.
Progress so far - I took a 6 gallon tank and hooked it to each motor to rule out bad fuel. I found that 1 motor runs like a top. The other motor would idle but not take throttle. I took the carb off and rebuilt it and found that the people that previously rebuilt it left the spring out that was under the main pump for the primary metering rods. I pulled the spring out of one that I found in the junkyard and put it in my carb. I put it back on the motor and runs much better. I still have to adjust the carb because it doesn't idle as well now. Here are the new problems that I have found. The tach for this motor shows that I'm idling at 1600 rpm when the motor is running slower than its partner who is idling at 900 rpm. The oil pressure,and temp gauges do not work for this motor as well. Does someone have a wiring diagram that I could get a copy of? What should I look at as being the culprit? The previous owner had just replaced the gauge pod for the upper station and it is not hooked up so I will probably need a little guidance on this as well.
thanks"
I have been w
"Hey everyone,
thanks"
