Problems with yamaha t50tlra, cuts out at 3/4 throttle
Lee Kent
I have 2002 yamaha 50 hp, starts immediately and runs fine until u throttle it from half to 3/4 throttle. The motor will cut out and recranks immediately, I have to repeat this process about 4 times and motor seems to finally draw enough fuel to run perfectly. It seems like a fuel pickup problem. Once I go thru the above mentioned process I can run boat at full throttle, until I throttle under half throttle and then have to repeat process. I have replaced fuel and water separate filter, I replaced fuel filter. Any helps would be appreciated.
Thanks in advance.
