I have a SP-A upper with a 290DP lower
I had shift problems last year so I pulled apart the upper transmission but ended up resealing the transmission and replaced the u-joints.
I am having to assume that the lower unit oil had degraded enough that the unit had too much friction. Not sure since the oil might have had all of 25 hours of use but everything looked brand new when it came apart.
When I went to put it back on the outdrive one of the trim seals blew so I decided to go ahead and reseal the lower unit as well since it was off.
Now that everything is back together shifting is great and all sounds ok but I am only turning 2900rpms at WOT. I used to get 4400. Top speed is also down 12mph
My engine temp is also running 25 degrees hotter. Not sure if this is from the engine working too hard or something else from removing the outdrive.
Could not look at the oil today rain poured as soon as we pulled the boat out.
Any ideas on what I may have done to cause the loss in rpms?
I figure I'll have to work on the temp problem after I get the outdrive back to where it should be.
