stanleylee128
"I bought a 2007 four winns 18
"I bought a 2007 four winns 180 with a 4.3 mercruiser turn key start carby motor 190hp. It only has 30 hours on it. First I found 2 bend valves on the left side head, so had it removed, repaired and bolt back on. Check compression, all good. It was running fine until the temperture alarm goes off when it gone pass 3500 revs. Once I back off, the temp was good again. The motor runs fine when cold but idle very rough when hot. Also notice a flat spot under 2000 rpm. I clean the carby twice already and is still running rough. So there are 2 problems, idle rough when hot and overheating on hi revs..........Any idea would be appreciated. Thanks."
