K
Kirk Eaton
Guest
Model# 856996
Serial# J00019
Model# 856996
Serial# J0001950
I have had this engine about 1 1/2 years. I am being told I need another Power Pack. This was replaced just last winter. Is this normal for an engine to go through a Power Pack a year? This engine also doesn't pee much water when it is running. It has the 2 holes just below the motor compartment. How much should it spit out normally? I also have problems with it dying when I put it into gear. This happens even if it is warmed up or not. Does this mean it needs to have the idle adjusted higher? This motor also came with a Whale Tail XL hydrofoil stabilizer. Is this thing doing me any good or is it just superfluous? The last time I tried to take my boat out it would not start and when I pulled it out of the water oil was leaking out of the small hole under the fin that the hydrofoil is bolted to. Is this just due to trying to start it repeatedly and the amount of fuel that was pumped into the engine? This is my first boat and I am trying to keep from being taken to the cleaners due to ignorance. I would appreciate any advice concerning what I should tell the mechanic and have him check. I apologize for the length of the post and appreciate any and all help and your time. Thank-you.
Serial# J00019
Model# 856996
Serial# J0001950
