Here's what's going on:
-Running it in my driveway: It takes 5-6 pulls to start and might stall out once. Then it runs fine in the driveway. I never put it in gear at home, but once going, it will idle just fine for as long as I want.
-Running it in the water: Takes 6-8 pulls to start and stalls out a few times. Usually I have to shift it into gear with a tiny bit of throttle turned which causes a jerk on take off, to get it to go without stalling out. This is still after warming it up for 5 minutes or so. Once I get going, I can idle/troll all day long fine. If I turn it off to stop and fish, and only stay in a spot for 1-2 hours, it usually starts right back up fine. If I'm stopped all day, I usually have to pull 3-4 times and it might stall once before it's idling fine and I can take off again.
-Where I fish: I only run it in salt/brackish water. Mostly in the Napa River or Petaluma River. I run it in the garbage can of fresh water for 5-10 minutes in my driveway everytime I come home. I was told that I should unplug the gas hose from the motor and let it run until it dies. I have never done this.
-Other thoughts: I am new to boats and motors in general and may just be starting it wrong. If I open the valve on the gas tank all of the way open and pump the bulb, it feels like barely any fuel is going through and I'm just pumping through air. If I only open it a little bit, it pumps through gas just fine. It's a this tube. How many times should I be pumping the bulb if I only open the valve a little bit? If I'm opening it all of the way and it feels like I'm pumping through 90% air, is there a leak? Possibly just needing to replace the gas hose?
I usually pull the choke out all of the way and once it starts, I push it back in. Am I doing this wrong? Should I push it in slowly? I've been told to "use the choke" but I'm not sure what that means.
I ran these same details past the folks over at iBoats and they were leaning towards needing to clean my carb. I ran this by a local mechanic and he said:
I don't really have much money, wife out of work and a baby on the way, but I'd love to get out on the water before he comes in February, while I still have time. Any help would be appreciated!!
thanks!
-E
SOUNDS LIKE YOU NEED TO USE THE CHOKE AND NOT SO MUCH GAS IF YOU CAN LOOK UP A MANUAL AND OR SEARCH FOR A DAHATSU FORUM ONLINE YOUR PROBLEM WILL BE SOLVED. IF YOUR FUEL LINE PRIMER BUBLE GETS SOFT AT ANYTIME YOU HAVE A AIR LEEK IN THE LINE THAT MIGHT BE GIVING A FAULTY START
thanks!
-E
