Problems 1985 115 evinrude
ohmsboy
"Looking for some suggestions.
"Looking for some suggestions. I have had problems the last year with my motor. Last fall the motor started acting up. It will try to die when I give it throttle and has lost speed. Normally does around 40mph and now is at 30. It ran fine over the winter months but now has started the same problems since the weather has warmed. I have done the basic stuff. Replace fuel lines, clean carbs, and replace spark plugs. Guess the next stop is the expensive shop. Any help?"
"do a compression test,spark t
"do a compression test,spark test,ck your fuel,for water.
shops are not expensive,compared to persons damaging an engine,trying to repair themselves,in the driveway."
