Love to read the forum. I took my boat out and I have a 87 150hp Blake max. The motor has just been rebuilt by a boat mechanic. First time out. It started but shakes a little. Every time I give it the throttle it dies. I took it home. Compression test is 130 on all cylinders. Good spark to all cylinders. Squirted gas in cylinders through carbs and all changed motor but the bottom 2 cylinders. Pulled plugs and squirted fuel in holes in bottom 2 cylinders and they fired. Plunged off each carb and it changed motor. But the bottom carb did not Chang the motor. No vaculm to bottom carb. What is going on? Problem with reeds or a seal of some sort? I have never been inside an outboard before.
