I stumbled on this site trying to figure out a problem with my Johnson, looks like a great site. So here is my problem.
I have a 1988 Johnson 150, that will not stay running on it's own. To start it I pump up the primer bulb, push key in while cranking, it fires right up. After starting up if I don't keep hitting the choke it will die. Last night I tried turning the red lever on the primer solenoid, with lever in normal position it will run like explained above. Move the lever full 180 it cranks runs and does not die, same if I turn the lever 90 degrees from normal. No choking with key. I did not know what the primer solenoid did until I found this site today.
I pulled one of the carbs just to look at it, no real varnish it was actually pretty clean. I did not go into the carb just pulled the bowl to look. Does this sound like I need to go ahead and tear into the carbs, or some other problem?
