bradamy631
"Hey guys,
I have a problem a
"Hey guys,
I have a problem and I am looking for some expert help. I have a 90 hp Johnson VRO. I purchased the boat this year, and it ahs worked great up until last weekend. i went to pull the kids on the tube, and the boat would not "get out of the water". this boat will normally do 42 mph, but it could barely do 16 mph. Interestingly, it would go (Somewhat) with the choke, but would never really get out of the hole like it should. I am mechanical, and believe it is either spark, or fuel (Most likely). The guy before me had the VRO pump replaced. No alarms are going off, but the motor seems hot. Lots of water is comling out of the "tell" so i believe the water pump is working. I replaced the primer bulb- the problem still persists. Could the VRO pump be F---ed up, spark, where would you start. the primer bulb is not collapsing (That i have observed) and looks/feels fine. After a 15 min stretch today of stop-start- pull the hood off, etc, the boat started working ok. Also, in the morning, when it is cool, it seems to work ok. When it ahs sat in the marina in the sun and has 27-32 degree celcius heat, the boat acts up. Where should I start? Should i disconnect the VRO (How would you do this)- just unhook the wires???- and hook a premixed tank up to the motor directly? It does have a built in tank. I am desperate and do not want to miss great fishing!!! Please help????"
I have a problem a
"Hey guys,
