I recently replaced the timer base on a 70 hp Evinrude and am having problems getting the WOT timing set. I tried the Joe Reeves method and going down the lake at WOT. The timing should be set at 17 degrees BDTC according to the carburetor cover. I can only get it set to 21 degrees before I run out of adjustment on the adjustment screw. This new adjustment is probably 3/4" more than the previous base and it seems that maximum advance is at 3/4 throttle. What do I need to do to get the last few degrees? I was also wondering if it could be stuck in Fast Start mode.
