I have an evinrude 25hp 1994 with electric start and primer. The only way I can keep engine running smoothly is to crack open the valve on the primer solenoid. When I put it in the run position, the engine surges. Carb has been cleaned and fuel pump rebuilt. Still can't set the idle unless I use the red valve handle to let some fuel directly in. Any ideas? The high speed jet is fixed. what is the initial setting for the low speed screw, 2 1/2 turns out from stop?
