alwayswrknonit2
"I have a 1988 Johnson 120 Loo
"I have a 1988 Johnson 120 Looper. The primer solenoid isnt working. I tried using the manual override but its just not working out right. Could someone tell me the proper procedure for cold starting and warm? And which way the red valve should be facing? Up or Down. Also, if starting manually, can this be done as a permanent fix or should it be replaced right away? Thanks"
