I posted this same issue about 4 years ago. Still battling it and hoping for some new ideas. I have a 1988 electric start/ electric primer Johnson 20HP.
The slow idle mixture screw has no effect on achieving a smooth idle. At idle, there was a constant flow of gas bubbles through the primer lines to the carburetor. I put clear lines on the primer so I can see it happening. It idles, but not smoothly, and as I said, I can be a 1/4 turn out from seat, or 10 turns out from seat and there is no change to the idle.
Is it possible that the bubbles of gas are providing enough gas to fuel idle? Why is this happening? IS it possible that I don't have the primers lines connected correctly? Can it be a faulty primer? I tried rebuilding it (did not put in new springs) but this issue remained.
Does anyone have a diagram of how the primer lines are supposed to be connected?
THanks!
Emil
THanks!
Emil
