So my 150 2-stroke Merc wouldn't start up this morning (it sat a few months but fired up ok last week).
So, like always I pressed the key in to prime and start and it was just turning over constantly like when the kill switch is off. No matter how much I primed it I couldn't get it to flood (100% of the time if I have trouble starting and end up over-priming I get a pop where the ignition kicks out and I couldn't make it do that).
I figured maybe the primer solenoid (I think its actually called the enrichment valve or something) wasn't letting gas in since it wouldn't flood even after priming quite a few times but when I took the cowling off it was clicking when someone pressed the key in and manually pressing the button on top of the primer solenoid/(enrichment valve?) didn't do the trick either.
What else could this be? It seems physically impossible to pull the hoses off, but if I pulled one of the two off at the solenoid what one would it be the top of bottom one (to see if priming is letting gas in)?
