Primer bulb wonbt stay hard
I got a 97 Evinrude E115GLEUC.
I got a 97 Evinrude E115GLEUC. I've replaced the prime bulb rebuilt the VRO pump and still I'm running out of fuel. The only way to keep it running is to squeeze the primer bulb?
The primer bulb wont stay hard
The primer bulb wont stay hard as the fuel pump sucks fuel through the fuel line it has vacume in it and generaly takes a couple of pumps to make the bulb go hard this is normal...however if you have to keep priming the bulb for the engine to run the fuel pump is not pumping fuel and will need replacing
"Pumping fuel primer bulb = ac
"Pumping fuel primer bulb = acting as a manual fuel pump.
Primer bulb stays full ONLY when installed in a vertical position with the outlet facing up. Fuel pump must also be in perfect condition.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
Could there be a check valve n
Could there be a check valve near the tank that is restricting flow? Happened to me once
Could the OP's problems be
Could the OP's problems be caused by an air leak into the fuel line or the fuel system on the engine. Pretty complex with lots of scope for bad joints ?
"Either you've overlooked
"Either you've overlooked something within the pump OR the pressure line that operates it is faulty, OR for some reason no pressure is being applied to that hose line."
"Eugene, you need to start you
"Eugene, you need to start your own thread so that you don't get lost.
Remove the flywheel nut, install a puller using the 3 tapped holes in the flywheel, apply pressure with the puller and the flywheel should come off."
