"Hello Carl.. Thanks for the h
"Hello Carl.. Thanks for the help... I have posted several other times regarding the Solenoid & Battery!I just bought the boat in Sept and didn't think I would have these problems with a 3yr old engine. I did figure out the simple wire delimma with the Solenoidd just didn't have any responses, so I re-posted where I left off. I did replace the Battery(Sears Die hard 550cca)and Solenoid($35), cleaned connections and still Solenoid Clicks. Like I mentioned boat mechanic tested voltage and had 12V at starter, and 7.4 at sides of Solenoid. Could there still be a bad connection between battery cables and starter, boat is a 1997 with 2004 engine. I really appreciate the help and it's obvious Iam not a electrical guru! Thanks for all your help! You too Joe, I wish you had the right starter.....
Chris"
