Scottybluewater
Good evening Gentlemen - need your help once again
Have the U-joint bellow installed to the Bell Housing - ready to bring the bell housing up to the Gimbal/transom in order to install the water hose - u-joint bellow - shift cable housing and bellow
I know the position of the gear clamps - installing the water hose first - would you install the u-joint bellow next or the shift cable bellow - the only way i can move the shift cable bellow is by lubing its housing
At this stage the bell housing can be moved around a bit - I am considering doing a - no adhesive - test run
Any thoughts are appreciated
