Was draining out the boat yesterday and noticed a small amount of gear oil leaking out from behind my prop. After removing the prop I expected to see evidence of oil leaking from the prop shaft seal but it was clean. No trace line.
I then drained the gear oil which revealed a small amount of water had gotten into the drive. 3-5 ounces if I had to guess.
To me it looks like the oil is running down from the upper half into the lower half and seeping out at the prop. Or perhaps it’s leaking passed the carrier bearing?
Any ideas?
Still going to pull the whole thing to inspect, just hoping for a little insight.
thanks!
Any ideas?
thanks!
